Hey guys,
I need advice on whether to buy a diesel or gasser. They are both used and 2021 models. Same options aside from the infotainment system, the diesel has the base infortainment without android/apple car play. The gas has the 8.4
I tow regularly, not daily but probably 10 times a month.
The vehicle will be a work truck, I need a 2500 for payload mostly because my 1500 was over gvwr every day. To the point where I had uneven tire wear despite the tires were rotated at every oil change and in between each oil change.
I need to know if the increased maintenance cost will be worth it with the diesel or if I should stick with the gasser. (The gasser does have more payload, obviously)
I will also use it to tow our camper as well. It is under 6k and I can also tow it with my gladiator which is diesel and gets 14mpg towing it..
