1 - 9 of 9 Posts
Discussion Starter #1
So a friend of mine owns a shop and convinced me to change my lights (reverse and third brake) to LEDs and my heads and fogs to plasma LEDs. The change looks great but we ran into a problem.
First, my heads and fogs needed flicker harnesses and resistors to work properly, but sometimes my right headlight will dim. But of course whenever I bring it in it works perfectly.
Second whenever I start my truck it says that my headlight and brake light is out, but they are working fine??
Any help would be greatly appreciated
Are you sure you have the right resistors in place? On my 12 I got the brake light out warning on my aftermarket led taillights when the resistor bank melted :i_rolleyes:
Discussion Starter #3
Not sure to be perfectly honest. The guy at the shop did the work. Not sure if it makes a difference, but I have a 2015 ram sport with the projector headlights and the led tail lights. The only parts that were changed out were the bulbs for the headlights, fog lights, reverse lights and third brake light.
I have a Magnum with projectors and HIDs. You need a relay to put more power in to the HIDs. Does the light dim when you do something else with the electronics, like turn on the AC or roll your windows down? If so, it's definitely a relay you need.
Discussion Starter #5
Thanks for the input man but if I'm not mistaken the plasma LEDs in my headlights and fogs actually use less power than the stock bulbs, and I believe its why they needed the flicker harness and resistors but I could be wrong. And wish that were the problem but the light goes dim randomly with nothing changed (that I know of)
I got nothing on your headlight out message but I can almost guarantee that something is wrong with the resister for your third brake light (or there is no resister). So your truck thinks that the third brake light is out. When the third brake light it out, it'll tell you that your right brake light is out for some reason...
Discussion Starter #8
Can you post a pic of your headlights and tell me which part is going dim?
Sorry I've been busy at work but it's the actual light itself that is dim. Drivers side is bright and works perfectly but the passenger side headlight is on but barely
Discussion Starter #9
Hey guys just wanted to update.
Turns out there was no resistor on the third brake light, so thank you Troops141. That fixed the problem.
As for the headlights that was a bit trickier. They had to wire the headlights to that side amber light in the housing so it would bypass the computer. There was just no other way around it. That computer was just relentless on not accepting those plasma LEDs. But thanks for all your help. All my lights are working great and no more alerts popping up every time I start my truck.
1 - 9 of 9 Posts
