1 - 12 of 12 Posts
I just bought aftermarket LED taillights from eBay and when I installed them they work find but when I open any of my doors the taillights flicker. Is this normal? I never had this happen to any of my other vehicles, this is the only time it's happen, just wondering if this is normal? I got 7 days to see if I need to return them, any suggestions?
Check the connections, pretty basic but you never know. Also, did you need to install a resistor or was it built in?
Discussion Starter · #3 ·
It has a built in resistor in them. I'm gonna check the connections again. When I hook them up I hook them up with the wires matching right? Like the black wire connect with the other black wire?
Discussion Starter · #4 ·
I Checked them again and they still flicker when my door opens but it's only the passenger side that blinks once then after awhile it stops. They still work correctly though, it's just when I open any door. I'm not sure if I should worry or not, or just to deal with it.
my LED taillight bulbs to do this too. I dont really worry about it. I also noticed when using my key fob to unlock my truck my pass side blinks before my drivers side
Discussion Starter · #6 ·
So SS4LUCK should I worry about it or not because like I said before other then opening my door and my passenger side blinks they work correctly. This must be a common thing on Dodges then.
Im not worried about mine. Been doing ti for almost 6 months and nothing has burst into flames yet lol
At least they are LED so you don't have to worry about them surging and burning out. It likely has something to do with the ground if its when the doors are opened.
It's probably due to the fact that the LED's need far less power to emit light than the old bulbs. I put LED's in my cargo light and they come on very dimly when I open my doors. There must be just enough current in the circuit to light them up.
I wouldn't send them back for that.
Darin
Discussion Starter · #10 ·
Ok thanks everyone, I appreciate the info. I'm happy with mine so I'm not gonna worry about them or take them back. I'll keep them, they look really good on my truck to :)
Discussion Starter · #12 ·
I'm not sure what brand it is but I got the black housing LED taillights, they match really good with my euro black housing headlights I just installed. My truck looks more badass and mean lol :)
1 - 12 of 12 Posts
