1 - 3 of 3 Posts
Greetings,
I just recently purchased a 2017 1500 with air suspension.
Are there any concerns if you take it to a tire store or shop and the put it on the rack?
I see there is a "wheel alignment mode" in the suspension menu. I am not sure what that mode does... does it just turn off the leveling?
Your knowledge is appreciated!
it doesnt do anything since it was on the air and it will not detect any activity. it happened mine and forgot before they changed the muffler. i was there and all suspension did not move at all.
Premium Member
Are wheel alignment mode & Jack mode different ?
i can almost picture someone having a flat tire & grabbing the jack to raise the flat off of the ground.
The air suspension senses that corner of the vehicle being higher than the rest & the suspension compensating to keep it level.
That would cause the vehicle to move slightly & fall off of the less than adequate scissors jack
1 - 3 of 3 Posts
