1 - 7 of 7 Posts
So, my deck is the base one with sat radio. Normally i would just pull the stereo and see where there is a grounding issue, but due to this truck only having 201kms on it, im not interested in spending god know how long to find the issue.
So here's the issue:
There is a somewhat hard to detect whine, coming most likely from passenger front door speaker. It occurs (for the most part) regardless of RPM or speed. I am aware that this might easily mean its NOT alternator whine but for lack of better explanation right now thats what im going with.
Further, I attempted to diagnose problem (ie. change gear, rpm, volume even cabin temp and other driving habits) and i cannot accurately recreate the problem twice. It comes and goes at will and is becoming annoying.
Any help would be appreciated seeing as if i cant figure out how to make it screw up, the tech prob wont either.
Is this a 100% stock stereo system that you have, or just a stock radio that you are using with other components? Alternator whine can be caused by a bad ground connection, interference from power wires on signal wires and a few other things. Give a little bit more info if you can.
Discussion Starter · #5 ·
oddly, both. i tested again today and at first i thought perhaps it was wind noise as it seems to disappear at certain speeds (ie i think under 40k.....not sure exactly)
Here's an odd way of isolating sound location, but it works. Get a 2-3ft length of garden hose, the 3/4" diameter works best for this. Have someone drive around, and with an ear plug in one ear and the hose held against the other, move the end of the hose around the trouble area. You can locate the exact spot of the noise this way, but you really look like an idiot while doing it.
Premium Member
If a diode is going bad in the alternator, it will cause a whine in the radio, but it is usually RPM connected
1 - 7 of 7 Posts
