Just finished up the install of AMP Research's Power Steps. Install is fairly straight forward but there were some minor glitches in the directions when it came to the emergency brake line bracket install.
The problem is mislabeled part numbers but no bother anyone can figure it out plus the parts for the brake line bracket all come in one bag. The only problem I ran into was when the steps would retract they got stuck and would not come out.
The instructions describe bouncing up and down on the boards to set them. I tried a few things till I realized I needed to bounce up and down just on the very ends of the boards. That caused them to adjust and took care of the problem. They work great and I love them. The lights that come with them are very small so I purchased a larger and brighter set of lights to replace them. I will install the lights in about a week.
I was missing one small bolt from the kit, I will call AMP and have them send me one. It's used in the pinch weld to lock in the bottom of the linkage. It takes two and I have one so no harm but will put the other in when it arrives.
I would definitely recommend, sorry no pics you can see them on a RAM on YouTube.
