1 - 6 of 6 Posts
Anyone know where the stock amplifier is located (if there is one)?
I have the 5.0 UConnect with the 6 speaker system and i cant figure out why all of my driver side speakers have stopped working all the sudden.. pretty sure they're not blown so i'm thinking i've got a bad connection somewhere
I've got the same radio as you. There is no separate Amp, just the head unit power g the speakers. It might be a bad connection where the harness plugs into the head unit or something wrong with the head unit.
COUld also bre pinched wire from cab to door. notorious for such
Discussion Starter · #4 ·
Thanks guys. I haven't checked the wiring yet from the door to cab so i'll look at that when i get off. Weird part is that even the driver side dash speaker is out so i'm not sure it would be a connection from door to cab since that wiring for the dash speaker most likely wouldn't run through the door grommet... but it cant hurt to look!
It's possible that a short at the door could effect the whole side
1 - 6 of 6 Posts
