So, I have determined that when I get home from deployment I will change my diff fluid. Its right around 50k, or will be when I get back, and though I consider that sort of early I have off roaded and towed enough to where I think it will be beneficial. As usual I searched the internet and the Z and couldn't find anything that answered my specific questions.
For the rear I will drain the fluid through the plug first, then pull the cover so I can inspect the gears. Its an LSD so its the one I'm more concerned about, and I want to make sure I clean out all the fuzz that is a byproduct of things with clutches (transmissions, clutch LSDs...). I'll be resealing it with silicone, nothing special there.
For the front I will probably just use the drain and fill plugs since its not an LSD, I am not too concerned with chipped gears or anything.
Now for the questions, I am probably overthinking this:
I really like Royal Purple, and want to use their max gear 75W-140. This says it already has LSD additive in it, but has anybody used it with a ZF LSD to confirm that it's enough? I don't want too much additive either, and I know you're supposed to add the additive before the oil. Should I put in 2 oz additive or something and then fill with the oil?
Redline also makes a 75W-140 without LSD additive (has "NS" at the end of the part number). They are supposed to make good gear oil, so I am considering just using this with the 5oz of Mopar LSD additive like the manual recommends. The Redline isn't MS-8985 compliant that I know of, but I am not super concerned with that since from what I can tell only the Mopar fluid is.
FWIW the Mopar LSD additive is the only one that meets the MS-10111 spec in the manual, but I am not super sure how important that is. I have always tried to comply with the manufacturer specs like MS-6395 for engine oil so I have only ever used Royal Purple other than dealer oil, which both meet the spec.
My 3rd option is to use Mopar diff fluid and Mopar LSD additive, but I feel like RP and Redline are probably higher quality. I have also read that the Mopar stuff has a higher level of sulfur in it :shy2:, of course that was on the internet so IDK how accurate it is.
For the front I can only find 2 companies that make a 75W-85 weight, Mopar and Redline. I know most people say just use 75W-90 but I am too neurotic to do that
. Anyway, I am going to use Redline up front, which actually has me leaning towards using the Redline 75W-140NS with Mopar LSD additive.
What are y'alls thoughts/opinions/experiences? Especially those of you with 2011+ ZF 9.25 LSDs.
