Hi, for about the last few months, I noticed a puddle under the engine the next day after use. The radiator also was losing coolant. I put two and two together... and....
Upon further inspection, it appears that radiator coolant is leaking from behind the main pulley that the radiator fan is bolted to. As in it's coming from behind the fan and from the engine block itself. Also, that pulley has some minor travel to it, about 1/8 inch while running.
How bad is this? And is it a relatively easy fix?
Thank you in advance.
