1 - 7 of 7 Posts
just installed 4.56's in rear not to bad made a spanner wrench and had to grindtooth for the king pin...just wondering if there are any surprizes in the front lol..thanks ready to knock it out:box2:
Were there any surprises in the front?
Discussion Starter · #5 ·
no not bad. took about 5 hrs thanks to the wheel bearing bolts being stuck. now i need to find out who make the gears to recalibrate my speedo. its 15 off and causing the tranny to shift premature.
I had a surprise. I bought the wrong part. The Dana 44 has two different size ring/pinion. I ordered a standard ring and pinion, but it is too small. I think I have to order a "thick". If the truck had a 3.92 (I think) or larger, then the standard is correct, but if it was smaller, then you need the other one.
So, I had my mechanic put the old one back in the front for now, and I just can't use my 4x4 (which really sucks in this country)
1 - 7 of 7 Posts
