Anyoen has Signal Acquistion Problems with OEM Sirius Radio?
3590 3
After 2 months, my OEM Sirius radio is constantly showing "acquiring signal". Its not an activation issue and every once in a blue moon it will lock for a few minutes. Has anyone had issues with the stock radio in this regard or for that matter the SAT antenna on the vehicle roof?
1 - 4 of 4 Posts
try and see if this happens in the same place on the road every time. i know one area where i drive home from work and one on way to work where ill lose a signal due to heavy tree growth over the road,same place all the time. thats the only time i get that and my radio has never locked although i do get a subscription update from time to time where the radio just stops till it updates. (about 10 seconds if that)
Discussion Starter · #3 ·
Sirius
No unfortunately it is basically always in that state. Location has no bearing. It worked fine for the first 2 months I have had the truck and now this. I believe I either habve a bad tuner or antenna at this point. Likely going to need to bring it in for service.
1 - 4 of 4 Posts
