https://www.obd-codes.com/p0355
The COP (coil on plug) ignition system is what is used on most modern engines. There is an individual coil for each cylinder that is controlled by the PCM (powertrain control module).
It eliminates the need for spark plug wires by putting the coil right above the sparkplug. Two wires are dedicated to each coil. One is a battery feed usually from the power distribution center. The other wire is the coil driver circuit from the PCM. The PCM grounds/ungrounds this circuit to activate or deactivate the coil. The coil driver circuit is monitored by the PCM for faults
If an open or a short is detected in the driver circuit for
coil #5, a P0355 may set. Also, depending on the vehicle, the PCM may also shut down the fuel injector to the cylinder also.
I would switch Coil # 5 with the one next to it
Then scan for codes again & if the fault code is no longer p0355 & it is now a different #, then you know that you have a bad coil
Read More :
