I have them installed on my 09 and love em, I leave about 3-5 pounds in which no load so there is less of a chance of pinching.
Hi konarider 2005,sigh.. lost all air in my air bags and seem to have a leak... so i wnet under to investigate and the place that installed them on my 09 didnt install the upper urethane mount on either side (professional install my a$$) so i imagine its one of the bags leaking. back to the installers i go i guess. :box:
First and foremost, Allow me to introduce myself. My name is Josh and I have ALOT (I do mean alot) of experience towing and hauling heavy loads. Having been in the army, and on 3 combat tours, for the better part of a decade now, I have seen and driven just about everything there is to drive, from tanks, to Route Clearance Vehicles, to pickup trucks. Some are VERY heavy, and some are bone stock trucks guys like you and me drive everyday.
If you are towing a heavy trailer (which you can do just fine), you will notice something profound almost as soon as you set your trailer on your hitch. Your truck will go from raked (the front end lower than the rear), to squatting. Your coil springs will collapse under the weight, and while that does not pose a problem to your truck immediately, it can, over time. Towing a load as heavy as this with the 4th gen Ram requires some additional help, due to the smooth riding coil spring Multi-Link rear suspension. Coils were put in the ram because they ride smoother, but they are your worst enemy when towing/hauling heavy. Thats where the good folks at Total Load Control Suspensions come in. TLC John will not only hook you up with great customer service, but Ramforumz members even get discounted pricing on their kits. This system is designed and patented specifically for 2009+ Ram 1500's. It will work in conjuction with your coil springs to improve load handling, reduce wear and tear on your coil springs, and even helps with unladen ride comfort and stability.
Right now, TLC is offering special pricing and free shipping anywhere in the US and Canada!
Shoot me a message, or an email at [email protected] and we can get you on your way to comfortable and safe towing. Happy Travels!
thats the one! im not happy with the install job at all.. was done a year and a half ago and im pretty sure im just gonna march in and have them redo the job. not a professional install at all...Hi konarider 2005,
Do you mean they forgot to install the Upper Support on each air bag? I just downloaded the Firestone Coil-Rite Install Instructions and this Upper Support sits on top of each Air Helper Spring. Looks like there is also a Lower Support for each as well. Let me know if this is the part you are referring to as I will have to pay careful attention to these during installation.
Thanks for verifying konarider2005. I will keep a close eye on this during my install.thats the one! im not happy with the install job at all.. was done a year and a half ago and im pretty sure im just gonna march in and have them redo the job. not a professional install at all...
Hi Bryan,hello canukhram.. I went with the TLC system also and am very happy.. I understand the cost is higher, but worth it. I acutally had the firestone bags first, but before installing them I found out the temperature range the advise to use them in. I was shocked to see that they are only good to about 15 degrees ABOVE 0 F. Living in Wisconsin this would not work for me. I actually talked to a firestone rep, and he said yes that was correct, but most people did not seem to have an issue. Well for me I was not willing to take that risk, since who wants to install them twice.
Just something to think about.. Bryan
