1 - 2 of 2 Posts
anyone on here running the 2.5" progressive rate coil spring from top gun customz? i'm currently running a 2" level and add a leaf in the rear and really looking to bring the front up. I dont think the level is actually 2 inches. The ride is also a little rough, so I'm hoping to get a little more clearance and a smoother ride.
if someone does have it, can you measure your height under your front bumper, or something so I can actually see If I will benefit
I don't have a 2.5'', I have a 3.5" so all I can do to help out is to tell you that the ride quality is much, much better than stock or a spacer and it did measure out at 3.5, actually a little more like 3.75", 2000 miles later and it hasn't budged. Just make sure you get the TGC coil and not the other manufacturers like Skyjacker, TGC gets their coils made by pure performance which is one of the top coil spring manufacturers. Hope this helps.
1 - 2 of 2 Posts
