Auto-Dimming Mirror Wiring Question
2565 3
I've got a 2012 Ram 1500 R/T with Auto-dimming rear view mirror. I'm trying to wire my V1 into it, but I need to know which wire is the +12v Switched and which wire is the Ground.
Unfortunately, I don't have a multi-meter to test with.
Any help is appreciated.
Thanks,
Shane
1 - 4 of 4 Posts
If you have same mirror as my '11 unplug the wiring harness at the mirror. You'll find a grey plug with two rows of 8 connections. Looking at side of the plug the wires enter the plug - count on bottom row 4 slots in from the left.. Wire is Pink (possibly with a blue stripe but I can't recall for certain and the light is too bad outside for me to see right now) but it is bottom row, 4th from left. 5th connection is empty. That's the power. Ground is black wire that should be 1st position top left. I use the Invisicord to wire my Excort there.
Glad I could help. That's what these forums are all about. I use the Blend Mount and Invisicord to mount and power my Escort Solo 2 -- it's a great system!
1 - 4 of 4 Posts
