1 - 4 of 4 Posts
Hi Guys,
'05, 81,000, SLT Q-cab, 5 sp auto, 3.92 L/S, Goodyear Wrangler HP on 20" wheels w/35% remaining tread. Just bought this truck and replaced the loud muffler.
It has a noise only at 25-20 mph that doesn't change in neutral or in a curve and only on decel (even in neutral). Almost sounds like a 12" section of each rear tire is a rough tread and the rest normal. Sometimes it's bumpy feeling and/or like theres a rock stuck in the tread. Totally smooth and quiet above 25 mph other than what I assume it typical tire whine. It doesn't do it until it's been driven 20 miles or so. After the 30 mile commute from work, I checked under there with an infrared thermometer and found no hot spots (pinion, u-joints, diff case, transfer case, axle ends, brake discs).
I've done a lot of wrenching years ago so I'm not lost as to how and where to check upon logical disassembly, but was hoping someone else maybe has already found/fixed a similar cause. I work 7 days a week and my sched is unpredictable so tearing totally into it isn't an attractive plan at the moment. I have ordered a 6 mic electronic "ear" and will jack it up next time I'm home.
Any ideas, procedures, comments would be welcome and appreciated.
PS. After searcing the forum, seems these things have a lot of rear axle issues. When I was young, you COULD NOT destroy a Mopar differential, believe me, I've tried! ... wonder what happened over the years with all the technological advances?...
My 2002 1500 had the same noise. Come to find out the bearings in the case were shot. I thought it was rocks stuck in the tire as well. Wish it was only that.
Discussion Starter · #3 ·
Thanks for the reply.
I have all the tools I need to replace those but left my long tube hex driver (for the carrier bearing nuts) at the last shop where I worked. Have to build another, wish I could remember what size it was... Still haven't pulled the cover off but will update the thread whenever I get to the cause.
Discussion Starter · #4 ·
I checked EVERYTHING out on the road and on jackstands with a chassis ear...
Seems the road noise is a bit more for these trucks than most opinions suggest. I had 8/32" of tread on the worst tire (wrangler HPs) and they all had edge feathering so I had a new set installed which seemed to eliminate the vibration/roar at the described speeds. And, I think there is a lot of echo noise from the bed with these trucks. I bought a dealer accessory set of bed fenderwell liners (which are standard equipment on the later models). That reduced overall road noise a LOT! :smileup:
1 - 4 of 4 Posts
