Axle paint shipping damage
1487 19
Just got underneath my new truck today and noticed they really scraped off a bunch of paint around the axles on each side of the diff. Looks to be all the way around and about 4 fingers wide. Looks terrible. Maybe done in transit by tiedowns on train or car carrier? Anyone else have this sort of issue? Question is, is this chassis paint damage something I ought to ask the dealer to fix or should I just get a can of chassis black and spray the bare metal myself before the rust sets in. I'm going to have to look over the entire undercarriage now.
1 - 20 of 20 Posts
I think if you look at most trucks on the dealer lot you will find the same.... I remember that mine had that as well however the dealer touched it up......
Discussion Starter · #5 ·
I guess I won't bother the dealer about it since its "normal". I have a can of Eastwoods chassis black somewhere which ought to do the job. It would really be best to use matching paint though so it will look right. Black paints are hard to match up. Does anyone know if the factory chassis paint is available anywhere?
Discussion Starter · #10 ·
Those that recommended flat black rustoleum are 100% correct. I have a bunch of different black paints leftover from past restorations that I color checked and the rustoleum was a perfect match on the axle tube. So, I have now feather sanded and spot painted the scrapes and it looks perfect. Thanks all.
I used galvanizing spray and then the black. - don't know if it helps or not
Premium Member
Discussion Starter · #14 ·
Axle paint
I thought about priming with zinc oxide, but elected not to since there wasn't any primer under the factory black. Figured might as well make it all the same. So I just used prep sol to clean and went directly to paint. If I was doing a restoration on an axle I would prime then paint. One other thing, the driveshaft isn't painted at all. Its bare metal. I'm wondering if I should remove it and paint or just let it oxidize naturally. Anybody got painted driveshafts?
Discussion Starter · #17 ·
Just doublechecked with a magnet, and my driveshaft is steel as I thought. I believe its a high tensile alloy, but it will likely still oxidize. Its still too new to be rusted so now is the best time to paint if I decide to go that route. Truck is a RCSB 4X4.
My RAM has an aluminum HUGE drive shaft. My last Chevy had steel and it got totally rusty at Pismo Beach. when I had it balanced and new center carrier installed, they painted it shiny black for me and it looked Purdy new :)
If you take the time to paint your drive shaft, make it a candy cane.
Discussion Starter · #20 ·
Well, I went and painted my driveshaft this morning. Wanted to do it before any rust starts since the truck is less than a month old (built 29 February). Went with the flat black rustoleum to match the rearend. Everything underneath now looks great.
1 - 20 of 20 Posts
