1 - 13 of 13 Posts
I how can i tell or where do you look to find your axle ratio?
You could either ask the service department for a build sheet from your VIN or look at the sticker that should be on the differential cover.
Yours should be a 3.55 or 3.92
Discussion Starter · #3 ·
Ok thanks i will have to take a look at the diff cover.
Discussion Starter · #5 ·
I went and took a look at the diff cover. Nothing on it.
Premium Member
send for a build sheet, it has Everything that your Ram has
even more than the window sticker
go here & then to customer assistance
ask for the Build Sheet
you will need you VIN# when you contact them
http://www.ramtrucks.com/webselfservice/ramtrucks/index.jsp
by the way, the axle ratio is glued to your right axle housing, if you went through more than a couple rain storms, its gone
If you still have the windows sticker, it will say 3.92 or 3.21. If it doesn't say, then it is 3.55(most common).
Discussion Starter · #9 ·
Thanks so much for everyone's help i now have the information i need.
On the rear axle theres a sticker that has your gear ratio on it. Its on the botton side of the axle on the driver side.
1 - 13 of 13 Posts
