1 - 2 of 2 Posts
Discussion Starter #1
I have a slight humming/squeaky sound coming from the front end around 10 to 40mph after that it goes away. Doesn’t matter if a hit the brakes, gas, turning etc. Seems like it is more on the driver side so I jacked up truck and moved the wheel back and forth and its solid but that’s not to say the hub bearing can still be going bad giving its got 110,000 on it. I just got this truck a few weeks ago so I’m still figuring everything out. Anyone have any ideas?
Glad to be a part of the RAM community thanks :)
Try spinning the wheel while it's off the ground and if it makes noise its probably the hub, just because you can move the wheel back and forth doesn't mean that the hub is still good.
1 - 2 of 2 Posts
