1 - 7 of 7 Posts
For a stock truck, what would be the advantages of going with an aftermarket shock vs stock? I do not tow or off road. Sometimes load the bed with several hundred pounds of stuff. If aftermarket, any suggestions? TIA.
The only real advantage to some aftermarket shocks/struts on a stock truck would be improved ride. If you are happy with the ride now, I wouldn't suggest changing shocks. If you want to do a level, then there are some real nice options for shocks/struts that will level your truck and improve ride.
· Premium Member
What Boosted said. Plus, the stock shocks don't last very long. They are cheap twin tubes. Might want to think about going mono tube if you do replace.
Discussion Starter · #4 ·
I am happy with the stock ride; compared to my last truck ('11 Dakota). However, if aftermarket would be a significant improvement, I'd do it, esp when it comes time to replace. What advantages does leveling have? How much does it negatively affect MPG? What recommendations for monotube?
· Premium Member
If you're not going to level then replace them when they go bad. May as well get your money's worth. Leveling doesn't really affect mileage. The mileage get's affected more by the offroad tires people put on after leveling. The advantage for leveling is you can put bigger tires on for offroading and for offroading in general. As for mono tubes. Bilsteins are great and should be more available now. Fox 2.0's are really great but more expensive than Bilstein's. There are others such as King and Icon but they are very very expensive.
· Premium Member
If you are not offroading you may not notice anything at all. The difference is that if you swap out twin tubes for twin tubes then they are not going to last very long either. Hence, going to mono tubes which will probably outlast your ownership of the truck. The order would be from least to best would be Bilstein, Fox/Icon, and the best of the best would be King. That said, the cost of mono tubes may be the same as several sets of twin tubes over the life of your truck.
1 - 7 of 7 Posts
