1 - 4 of 4 Posts
Discussion Starter #1
I have an older style OEM bed extender (82207107) and an OEM tri-fold tonneau cover on my 2014 Ram 1500. The problem I have is that I cannot latch the cover when the extender is hooked in and pivoted into the bed. The lever hits the top of the extender. I have it rigged now where it's not hooked in and I have a piece of wire on each side so I will not slide to the front of the bed.
Does anyone have a workaround for this issue? I also see there's another extender that locks on a 45 degree angle (82214148) but not sure if I'll run into the same problem.
Premium Member
To clear the rails for my tonnuea cover amp recommended the quick latch. Not sure if the older factory extender the same latch system but it solved al my issues. I can't flip but can unlatch pull out flip and latch. Works great. http://www.amazon.com/AMP-Research-74605-01A-BedXTender-Mounting/dp/B0041G1C0Q[/URL]
1 - 4 of 4 Posts
