1 - 6 of 6 Posts
Discussion Starter #1
Ok all. Bad news ? coming home in the snow today I had a wreck in my truck. Thankfully ok. I guess I hit some ice under the snow, spun around on a curve crossed the road and through a ditch into a telephone pole. Well now that's done here is my question. I haven't had time to have the truck checked out to make sure the frame is ok but I'm assuming it is. I have already found a couple good beds of the same year but want to know if the mounts on a two wheeler is the same as a four wheel drive? Swapping beds should be easy . But not if the holes in bed are different. And are all 1999 short beds the same length? Any advice appreciated.. CD.
Premium Member
Discussion Starter #3
But does anyone know if mounts are the same ? Several years back I swapped a bed on a different model truck and the frame on the 4 wheel drive was different then a two wheeler
I gave up on those body mount bolts long ago. I replaced them with 5/8" galvanized bolts and washers. Makes it way easier to remove for maintenance and cleaning.
1 - 6 of 6 Posts
