1 - 9 of 9 Posts
Discussion Starter #1
So it looks like a Bedrug mat is not available for a '15 2500 6.4 bed (factory spray in bedliner) w/Ramboxes. I contacted the vendor and they said they had nothing that will fit. I asked about getting one sized for the bed without Ramboxes and trimming it, they simply said its not recommended. Has anyone tried this or have an alternative?
night be better off getting a spray in liner and a heavy rubber mat that you can trim if needed.
Looks like the OP already has the factory spray in bedliner. Rubber mat is a good idea in the interim while waiting and hoping they produce a bedrug.
I did check with Auto Anything where I got mine & they don't list it for the 6'5" bed. It's unfortunate as the Bed Rug makes for a very nice addition to the spray in liner as they look like a matched set.
I though I seen a post on here where someone said they got a bed rug through Mopar. It's worth checking out.
I do not have the rambox but have a bedliner in my quad cab 1500. It is possible to trim it but you need a tool that will cut it because its very robust.
I'm ordering a truck with a 6'4" bed and the Rambox option this year and was disappointed to find out that Bedrug doesn't make a product for these trucks.
Are there just enough sales to warrant it???
bedrug make a generic rug which measures about 100" x 70", i bought it and cut it to fit my 1500 with the 6'4" bed with ramboxes.
the access mat is also a good alternative which i only found out about after ordering the bedrug.
1 - 9 of 9 Posts
