1 - 3 of 3 Posts
just ordered the belltech 2/4 drop kit for my 2012 express regular cab 2wd. Has anyone done a write up or anything on the install and how bad it was. Ive never done any suspension work really and scares me to try it. thanks
I just did my install about a month ago. It wasn't to bad, Took me and my buddy about 4 hours but we took breaks and stuff. Only pain is the rear shocks. Make sure you remove the plastic wheel well liners from the rear and use a Crow's foot wrench to reach the top nut for the shock. Everything else is pretty straight forward. Good luck!
Yep, stangallmotor nailed the hardest part of the install. Take out both rear wheel fender liners and get you some crow's feet wrenches for the rear top shock bolt nuts. These are located in a spot that is just about impossible to get to without them. Other than that, it is fairly easy to do. Good jack or two and stands are a MUST!!!
1 - 3 of 3 Posts
