Old Hot Rod,
That's the same result I had with my 2.5" Day Star. I've come to grips with the variation.
Old Hot Rod,Hay Schnitzer 21 , before i installed my leveling kit their was 2 7/8 difference from front to back, after the 2 1/2in. leveling kit the back is still 3/4in. higher, but it looks level. I would definitely get the 2 1/2in kit. Measurement from ground to top of wheel well front is 28 1/4in. back is 29in after instalation.
I dont think you can find a kit made any better than H.B.S. they are very nice pieces.
Just make sure to follow directions, it tells you to do both sides at the same time, this is good advice because the sway bar ties the lower arms together and they wont go down far enough to install the kits unless you do both at the same time.
Good luck and I hopes this helps!!!!
Yeah there is definately a difference there. I would recommend going with the HBS very good quality part and good results.Your kit looks so nice, and I am so dissatisfied with my 2.5" Daystar, that I just asked the dealership to switch out the Daystar (which they recommended two weeks ago) for the HBS. Let's see what happens.
Looks really good, thanks for the pics :smileup:Well I was able to get a few free hours over the weekend and got my 2.5" HBS leveling kit installed. Took me about 3 hours to do, but I LOVE it now. Before and after pics below. Thanks to old hot rod for suggesting I go with the 2.5" instead of the 2". He was right and the rear end sits right at 1" higher than the front but looks level. Very happy with the part and results!
Here's my 2.5" Daystar compared to your 2.5" HBS.
