Status
Not open for further replies.
1 - 20 of 552 Posts
Composite
2010
First release
exclusive to ramforumz.com
Airflow Innovations Corp. is proud to introduce the BFI Composite air intake.
Official release exclusive to ramforumz.com
The best performing intake for the 2003-2008 Dodge RAM trucks
equipped with the 5.7(HEMI), 4.7,3.7 engines.
Introductory prices start at
$329.00
For ordering please see information further below in this thread
CONSTRUCTION​
The BFI composite air intake is made up from 2 primary pieces, the main body which holds the filter
and the short tube which connects to the throttle valve.
The large elbow or main body is 6 inches in diameter ID tapering to 3.5 inches ID.
The main body of the
BFI composite air intake is constructed from advanced forms of braided and formed fiberglass,
bonded together using a high heat resistant Viynl ester resin.
To complete the
BFI composite main body the exterior is finished with a high gloss black Gelcoat
and I am proud to say it is MADE IN THE USA.
The short tube is a 3.5 inch custom "made to our exact specifications",
Silicone hose constructed with 5 layers of polyester braided weave,
built using "first use" Silicone, finished in a high gloss black finish on both the inside and out.
The Silicone short tube allows us to create a complex shape and remove 2 clamps.
Using Composite materials allowed us to smooth out the transition between the large elbow and velocity stack (cone shape)
at the same time perfectly matching the radius of the large elbow, this transition is extremely difficult to achieve
and we are extremely proud of the final product.
Looking at the picture above you would be very hard pressed to tell the difference between the 2 versions,
the biggest visual difference are the 2 less clamps creating a cleaner look.
Bracketry
Redesigned attachment points and brackets to withstand "severe duty" use
Built from Stainless steel, 2 versions, adjustable to fit all RAM truck configurations.
Finish
BFI composite comes with a Black gelgoat that is polished to a high gloss finish, this is a durable finish resistant to heat and chemicals
and if scratched can be easily wet sanded and polished to make it look like new again.
Warranty
The BFI Composite air intake carries a "Lifetime Warranty" main body and filter​
BFI composite a complete system ready for you to install
Starting at $329.00
Shipping add $30.00 anywhere in the USA-Canada
Includes
• High gloss Black gelcoat finish (exclusive to BFI)
• Your choice of 8 different filter colors no additional charge (exclusive to BFI)
• Individually numbered hand-crafted pewter plaque (exclusive to BFI)
• Removable PCV connector (exclusive to BFI)
• Stainless Steel T Bolt clamps provide worry free mounting
• IAT grommet included for stock IAT sensor
• P.C.V. hose made from synthetic rubber.
• Printed installation manual, web download also available.
• Lifetime transferable warranty, main body and filter
BFI options
Filters (no charge color option)
• One of the largest filters available for the HEMI engine
provides maximum protection for your engine, 6” x 8” inch
• Available in 8 different colors, (no charge option)
Black, Red, Yellow, Dark Blue, Sublime Green, Gomango, Plum Crazy Purple and of course HEMI Orange
• Made in the USA to our specifications by Green Filter USA
• Lifetime warranty
• Stainless Steel mesh protecting the filter media and end cap.
• 3 layers of Interwoven cotton filter media
• Filter recharge kits available in all colors
Polished clamps$9.95pr
• Our top flight T Bolt Stainless Steel clamps with a polished finish
IAT relocation $49.95 to $59.95
(see below for a discussion of the application of this option)
We offer 2 different relocation options for the IAT (Air Intake Sensor)
Both options include an extended factory harness, depending on the year,
can be installed without having to splice into the original wiring harness.
• 3ft extension; relocates the IAT toward the filter end of the intake $49.95
• 5ft extension; relocates the sensor outside of the air intake allowing for
placement at the front of the truck. (includes a protective cover for the sensor) $59.95
PCV relocation $19.95
This option allows for the oil breather tube to be redirected
rather than being attached to the air intake.
• Includes hose, clamps and a color matching breather filter.
Pewter plaque engraving$14.95
• We offer a custom engraving service, up to 15 characters.
Custom painting
We offer a full custom painting service with a “piano grade” finish.
• Colormatch to any Dodge/Chrysler vehicle $75.00
• Custom colors are also available (call for quote)
Custom Airbrushing
Available as a stand alone option or added to our custom paint option.
We keep a variety in stock, call or email us for a picture of available inventory in your color.
Numerous styles are available, smoke, flame, lightning or combination's.
Also available, true “one off” custom airbrushing available.
• Smoke, Flame or Lightning airbrush (3 color) $125.00
ARIA air intake shown
BFI
accessories
• Designed specifically for use with our filters,
• Kit includes 2 separate items a cleaning solution and color matched oil to recharge the filter.
• Recharge kit will last for 10 complete cleaning cycles.
• Available in all 8 colors
Replacement filters
• Available in 8 colors,
• Life time warranty
• Includes clamp
• Stainless steel polished end cap
Prices often discounted for current ARIA air intake owners.
Performance Packs (Diablosport)
Diablosport Predator and Trinity
• Combine your ARIA air intake with either the Diablosport Predator or Trinity tuner available at a substantially reduced price when combined with a BFI air intake.
• Pricing does fluctuate due to market conditions, we strive to offer these tuners at the most competitive prices, please see our web site for current pricing. www.bfiintake.com
Ordering
NOTE; Our website will be updated with the information contained above within the next few days, if you have any questions please contact us.
Please visit our web site www.bfiintake.com or our corporate site www.airflowinnovationscorp.com
If you have any question including custom orders etc. please contact us by phone at our toll free number 877-670-2233 or through the contact us portion of our web site.
© 2008-2011 Airflow Innovations Corp. All Rights Reserved
Discussion Starter · #2 · (Edited)
Current order list
(I will update this list on on Tues-Wed)
T. Cush
C. Cooper
A. Scardillo
M. Sink
J. McKinnon
M. Izzo
D. Sweigart
M. Negulic
C. Leombruno
J. Campbell
O. Chung
W. Lyman
S. Hensinger
C. Osbourn
T. Montanez
K. Ready
A. Chasse
D. Line
Very nice! So when are the orders that have already been placed going out? I am ready for it!!!!!! :smileup::Hey:
Look there I am #5! Awesome! Can't wait!
yes, yes.
god i thought mine would be a lot farther down the list.
Discussion Starter · #7 ·
I will update post #2 later this week with more detailed information for both current order and new order expected delivery times.
Current orders; will be delivered, depending on configuration, within 7-30 days.
New orders; I anticipate a time to delivery of approx. 30-45 days
HAH HA HA HA moparmadness i am before you :) lol
lol i cant get you mad :( aw
jpaul51 and cosbourn what are your numbers?
i am 2 :) lol jk i am 8
1 - 20 of 552 Posts
Status
