1 - 2 of 2 Posts
1996 Ram 1500 5.9 Magnum
Starting off with the things that work... The dashlights, headlights, highbeam, running lights, and AC all work. Unfortunately as far as electrical accessories, thats it.
The headunit is brand new, doesnt work, all interior lights and 12v ports do not work. Cruise control is also out. Basically all accessory power in the cabin does not work. When i try to put on my turn signals or hazards, nothing at all, not even clicking. When i step on the brake, the lights do not light up and the third brake light is completely out.
Please help me. Ive checked fuses and all that are in the fusebox come back with a good reading.
You need to get a meter and start checking voltage from the fuses back. I would start with the brake light first. If you have power then it's a ground issue.
1 - 2 of 2 Posts
