Before I place this order, what are the pro's and cons to each?
-I only want to level. I have no intention of lifting my Laramie any further than that as I am a disabled veteran and cannot climb in and out of anything higher than a leveled truck without serious discomfort and risk of falling.
-I will only run a 33" tire, at the most.
-Planning to run stock wheels or (if I do change wheels in the future), stock offset.
-I do not want any accelerated wear and tear on the suspension components.
Knowing these facts, which is the better route to go? If I do the daystar kit, or similar, the strut comes out and the spacer goes in, then the strut goes in. Then alignment. Does not seem that it would change the suspension geometery all that much, and as a result, seems to me it would have less wear and tear.
On the other hand, the bilsteins are easy, and cheap, and my truck has 50,000 miles anyway so its not a waste at this point to change the shocks. How much stress do they put on ball joints and tie-rods when set at 2.8"?
