Bilstein 5100 and spacers?
1 reading
7.5K views 13 replies 4 participants last post by  #Mt08Ram
#1 ·
It's it possible. My truck still don't sit quite level.
#2 ·
No, you can't stack Bilstein 5100's and spacers. The control arm and CV shaft angles become far too steep. If you want more front end lift you'd need to go with a full 4" lift kit to address the front end geometry issues that arise when lifting that much.
#7 ·
How did you even get 5100's on a Gen 3?
#9 ·
Ok. I think I understand now. You got the 5100' but they provide no lift since it's an 08. You are asking if it is ok to use spacers with those shocks. The answer is yes. I think both Brandon and I were thinking the were the leveling 5100's. My bad. If you want to level it is your only coice to use spacers since the Bilsteins won't level for you. Put a little more info on your truck in your sig and it will help others know what you need.
#10 ·
I bought the ride adjustable 5100 for my 08 1500. Installed at the max which is 2" lift from strut. That still leaves me like over inch in a half rake. So I've been contemplating seeing them at the sock height and putting 2.5 spacers on. Then I got to thinking if I got up to the second setting it would give me a little over 3" lift with the adjustment on the strut and the spacers being used at same time. But I've read that you don't want to go over 2.5 in front or you put added stress on front end parts? Ideas? Also I'm going to add to the sig like you mentioned. Fairly new to posting on forum, Didn't know about it. Thanks for all your help guys.
#13 ·
That is correct Brandon. I used to run 2.5" spacers on top of stock strut which had my 2008 1500 sitting closer to level than what it is with the adjustable Bilsteins at Max. Which is a half inch shorter. How a half inch makes that much s difference I don't understand. Just trying to get closer to level I once had with just the spacers. I also run 35x12.50r17's. this the reason I'm trying to get the most out of it without going to far or sitting on a Bro-lift(higher front) haha. Thanks again guys
