1 - 4 of 4 Posts
have the 5100's front and rear. front is set at the highest setting. anyone see this happen before?
also my first post, so Im not sure if the attached photos will even show hahaha
From what I understand, this happens when washer is placed under the nut instead of between shaft and upper mount.
Moderator
As MikeyA stated, the washer was installed in the incorrect location and the shock rod has now pushed through the upper spring seat. You'll need a new upper spring seat (I'd replace both sides), the struts will need to be disassembled to replace those parts, and then put back together ensuring the washer is in the correct location.
Discussion Starter · #4 ·
Thank you for the replies. Just finished the install with new strut caps. With washer in correct spot.
1 - 4 of 4 Posts
