1 - 4 of 4 Posts
2013 Ram 1500 my blower stopped working on speed 2 all other speeds work fine. Do you think its in the switch or a bad resistor ? Can i just change the resistor or do i have to change the blower motor, any help would be greatly appreciated .
Do you ever run the thing on speed 2? What would happen if you used Speed 1 or Speed 3 instead? I'd say forget about it and keep on truckin'. Some problems are best left unfixed.
Check the molex plug at the blower motor for a loose connection. You can find it behind the glove box. I had the same problem on my 2010, it was a loose connection on the 2nd speed pin.
Good Advice!
:rep:Rep Points Given.
1 - 4 of 4 Posts
