1 - 5 of 5 Posts
I went through a carwash with the high pressure blower and apparently had some leakage which I know is common with the Ram. The third brake light quit working. I replaced the bulb which was obviously blown. Brake light works again but the dash still says brake light out. Does the truck need to go through a certain number of restarts to clear the message or is there a further issue?
Discussion Starter · #2 ·
Since nobody seems to know and someone else may want info...after a couple restarts I no longer get message
You’ll have to reseal your third brake light also. I’ve blown a few lights before I found that the light needs to be re sealed with thicker material.
1 - 5 of 5 Posts
