1 - 10 of 10 Posts
Discussion Starter #1
Purchased my 2011 Ram 1500 with 5.7L Hemi new in 2010. She is used more for transportation with insignificant cargo weight & has never pulled a load.
Just turned 44k miles & it sounds like i need to work on rear brakes & although the engine runs great, I should be changing the original plugs.
Have a few questions:
1. Is it a good idea to replace pads and rotors on all 4 wheels at the same time? Or, do you think it is likely that the fronts still have a way to go yet? My personal preference is to do all at the same time; however, if I still have a year or more on the fronts, would leave them until later. A friend said that it is unlikely that I need to replace or turn the rotors. On my other vehicles, I've always replaced them. One idea I had was to replace them and then take the originals to the machine shop to be turned for the next job. I only ask the question because I understand some of the newer pads are more forgiving if the rotors aren't perfect(don't squeak).
2. In replacing the plugs, I'm inclined to remove the front tires & liners for easier access. If I replace the front pads/rotors at the same time, I could be killing 2 birds with one stone, so to speak. Do you think going in from under the truck works better? I'm 5'8" & usually use a step stool to clean & maintain engine.
3. The pads and rotors seem to be sold in kits: 1 for the rear & 1 for the front. Is there a particular brand you like &, I assume, I would use the same brand for front & rear?
4. What is your favorite 100k mile spark plug for the 2011 5.7L Hemi?
Thanks for your help. Steve
Premium Member
Spark Plugs
Original Equipment was
NGK 92174 {#LZFR5C11}
Dual Plug; Gap 0.044"; Actual FCA OE NICKEL plug (30,000 mi/48,000 km interval).
alternative plugs that they began using in the 2014 Ram
I don't know if you have to replace the coils to use them, it might be worth researching
NGK 92145 Laser Iridium
Dual Plug; Gap 0.044"; Recommended FCA IRIDIUM OE extended service part (100,000 mi/160,000 km interval)
Brakes
several members have gone with the Power Stop brand
https://www.powerstop.com/products/#y=2011&mk=RAM&mo=1500&p=Front & Rear
Super Moderator
At 44,000 miles I am surprised you need to do pads or rotors; I got 75,000 out of mine and I do tow and haul. I'd probably just change the fluid and if they are squeaking you may just need to grease them.
For a 2011 spark plugs are supposed to be done every 30k so you are overdue if they haven't been done already. I just use the NGK nickels and do it every 30k on mine instead of using 100k plugs
Discussion Starter #5
Thanks, Thunderhorse!
I agree & I'm easy on brakes. On the way home from the holidays, had a blowout at 85 MPH in New Mexico; pretty scary, but within an hour had the spare on and continued for 1500 miles with no indication of brake noise. However, when I started her after we got home, there was a definite dragging sound from the rear. Perhaps something could have been damaged? I suspect I'll have to pull the tire & inspect.
Is anyone aware of, if it is not pad wear, any other possibilities? I will pull the wheel & inspect before I go to the parts house.
If you do change your brakes, I have found rotors are not really expensive so I change them out with the pads. You might want to take a look at power stop.
Mine goes through brakes every two years. I swap it all. Only takes an hour.
Discussion Starter #8
Thanks for sharing your experiences. Great info. Passed through a mountain pass about 30 miles prior to arriving home. After inspecting, have plenty of pad & negligible rotor wear. Appears the sand compound used on the pass road was the culprit. Cleaned the noisy wheel(not the wheel that had the blowout) & the sound is gone & she is braking well. Will let you know if problem is not solved.
plugs
Go with the standard NGK plugs. I get 70k and still don't look that bad. I tow 20 bassboat. Have tried others and not worth the extra cash.
Just changed mine with the new NGK Ruthenium plugs. Had to special order them and got them cheaper than the iridium plugs.
So far, so good...but it’s only been a couple of weeks.
1 - 10 of 10 Posts
