1 - 5 of 5 Posts
Order placed and items are starting to arrive.
2012 Dodge Ram 1500 Crew Cab w/ Media Center 430N
- LC6i - Line output converter with Internal Summing
- Dash: Infinity Kappa 32.9cf
- Front: Infinity Kappa 693.9i
- Rear: Infinity Kappa 693.9i
- Amp: Infinity Kappa 4
- Subs: RE Audio SEX 12 DVC - Wired to 1 Ohm (Hope they fit)
- Mono Amp: RE Audio XTX 3000.1
- FoxBox: 2-12" Vented
- Install Bay AK01 - Dual Apm Install Kit
- 75 ft. Kicker Full-Spec Hyper-Flex Twisted Pair Speaker Cable (16 AWG)
Yesterday I completed the amp rack installation. Came out great!
More to come...
Discussion Starter · #3 ·
Mounted the amps, LC6i, and adjusted my FoxBox to fit RE Audio SEX 12" Subs... Installing 4 Infinity Kappa 693.9i tomorrow...
Discussion Starter · #4 ·
Well the build is complete and I could not be happier. The system sounds amazing. At half volume with the amps at 50% power it is louder then my ears can handle. Simply amazed...
Does your backseat rest on the box, which I assume is a fox box. I just installed a box in mine and the seats rest on the box. I am concerned about damaging the speakers, so I put grills on them. Now when someone sits in the back seat you can feel them. Which is terrible. Did you run across this issue? If so, how did you fix it. Thanks for your help!
1 - 5 of 5 Posts
