1 - 3 of 3 Posts
2012 1500 Sport. KN intake, 90mm bbk throttle body, bbk ceramic headers,cat back borla exhaust, bully dog tuner. Looking for suggested agressig shift points for a smooth pick up. I'm experiencing kick back then a quick take off when I step on it. 6 shift points by default. Any help welcome.
Best thing that you can do is put it on a chassis dyno. See where highest hp is, then you can set it a couple hundred rpms higher, or a bit more. After putting a hot cam in my 05, I dynoed it and saw the graph climbing at shift points, we kept raising the shifts to 6,300 rpms and finally got the best performance. Had I not raised the shift points, would never have known what a great cam. Also installed a 3,000 rpm stall converter. Day and night improvement. I now have 275,000 miles, I guess turning the hemi to 6,300 had no ill effect.
1 - 3 of 3 Posts
