1 - 15 of 15 Posts
2019 Ram 1500 3.6L V6
Intake Cam on passenger side excessive wear others are good no wear
Truck has the 85000 miles but should this part have lasted as long as the others in the truck? is there anything that I can do? It was a $3,500 repair
Not to mention last year replacing the transmission at $62,000 miles
Rectangle Gas Household hardware Nickel Wood
Milling Machine tool Tool Cylinder Machine
Camera accessory Camera lens Automotive tire Cameras & optics Auto part
Unfortunately this is a common issue with the lifter rollers locking up and grinding off the lobe. Its why I still change my oil every 3k miles. Oil is cheap replacing a cam and lifters is not.
Discussion Starter · #3 ·
I agree change in oils is important and I do so I wonder why only one cam was worn everything else very well lubricated
When you change your oil do you get an oil analysis?
Oil analysis.. how many people actually act on what it shows? Do they see higher levels of bearing material in the report and say "oh my god, my engine is falling apart, I need to get it rebuilt?".
nope.. they just say "hmm.. something to keep an eye on" and pay the same amount for a rebuild when the bearing start knocking..
Does anyone know how long it takes for a cam to wipe itself? On a flat tappet cam where lifter stops rotating? 20 minutes has been recorded.. a non rolling roller? prob same amount of time..
You don’t think it could give signs of a problem before it gets to serious?
It can but its only useful if you have the money to do something about it now. Most people I know that did it regularly and found they might have and issue still ran it untill it broke and just replaced the engine because it was still cheaper then paying for an overhaul. They just went about saving money for the new engine or started scouring junkyards for a used one to keep ahold of until the one in it finally blew.
Now if your in the business of over the road professional truck driving there's a huge benefit in that rebuilding a 15L engine is cheaper then replacing one, and you'd want to do one before catastrophic failure. but in a dodge ram. maybe on the cummins.
A friicking men.... even a cummins is kinida being overkkille... "OMG, it shows piston ring material,. I need a rebuild now!! " when the wear is actually normal
I’ve got the lifetime powertrain warranty, so if there’s a problem ram is fixing it.
1 - 15 of 15 Posts
