1 - 13 of 13 Posts
I want to do a camshaft in my ram. I have a cai ,exhaust and diablosport intune. What cam should I get? Should I change the valve springs?
depends how aggressive you want to go, are you 2wd or 4 wd? If you want it to be pcm friendly the comp 260 is a nice cam...as for springs you want to get 16x 6.1 exhaust springs and 6.1 pushrods...
Discussion Starter · #3 ·
Its 2wd. I have no idea about camshafts. Just heard it was a good power adder. I also want to get long tube headers at the same time. I am kinda leaning towards comp came or lunati. I don't mind get a custom tune
if you don't mind a custom tune then you can look at inertiamotorsports.com , Stu has some really nice grinds to choose from...great guy to talk to also, call him, tell him what you got, what you plan to get, and where you want the power to come and he has a cam for that... I wanted a more midrange type of cam which was aggressive (at the time).. mine does require custom tuning but once dialed in, my truck is a dream to drive... I have the Spartan cam
yup..2003 is the wicked stepchild for pcms... just get a mild lsa cam and you should be good.
what we had to do with one 03 we installed a cam in was use a psc1 piggyback to pull a little fuel at idle
Discussion Starter · #10 ·
I love a challenge! My other vehicle is a Jeep wrangler so it's in my blood LOL! So should I get headers first? Long tubes or shortys?
Buy a compcams adjustable pushrod checker thats what im in the process of doing. To insure i have the correct pushrod length. You will get the maximum performance out of your cam with the correct pushrod length and it will eliminate the dreaded hemitick for the most part... Dont assume that 6.1 pushrods will work with your motor cause not every motor is the same... Here is the tool in action, now i know that this is a completly different style head but the priciples still apply. And plus this is what STU at Inertia does with his motor and if STU does it then it right.
http://www.youtube.com/watch?v=Cqx8Cs6O6Vo
Oh and btw if you are getting headers bolt them to the heads while they are out of the truck its a life saver and will cut intsall time in half. Just dont forget to install the lifters before you put the heads on cuz somtimes its easy to get caught up in the moment. And take your time make sure you give yourself plenty of time for the install and make plans if things go bad.
1 - 13 of 13 Posts
