1 - 6 of 6 Posts
I purchased this tank from Titan as per their specs. Yes, this is Gasoline not Diesel. Has anyone done this before... Can use some help... Thanks...!
Gas Auto part Machine Personal protective equipment Metal
Machine Auto part Art Automotive lighting Gas
Gas Bicycle part Rim Motor vehicle Auto part
Boy it sure dont look like it is going to fit in same space as the other came out of.
Discussion Starter · #3 ·
The fit was not the problem, it was all the extra hoses. I have a 2021, Ram 2500 6.4 Hemi and they said it would work, ( Parts Geek) I have not found anyone that has done this yet...
2014 Ram 1500 Express 5.7 8Spd
not for nothing but i dont see any extra hoses, looks like they all have a spot to transfer to on the new tank except for one in the middle which looks like it will need to be tee'd in to the line
You should double check with Titan. As far as I know Titan does not make any gasoline tanks, only for diesel. If you're trying to modify a diesel tank, good luck.
1 - 6 of 6 Posts
