1 - 6 of 6 Posts
Can a 2008 Dodge Ram 1500 4.7l v8 engine be installed in a 2009 Dodge Ram 1500 with a 4.7l v8. Not sure if these are compatible. The 2009 has the flex fuel option, is this a problem.
Super Moderator
I know they upgraded the engine to make more power at some point, and I believe it was 2008. They added a second bank of plugs and some other stuff; I want to say yes, but you're also dealing with 2 separate generations of truck so the controls and electronics may be different
Discussion Starter · #3 ·
Thanks for the reply. Not sure what to do here. The salvage yard said the 08 and 09 were compatible. The 08 4.7l engines I found on ebay when I plugged in my 09 truck in the compatible chart at the bottom of the ad it said they were not. Looking for some verification this will work as I can only find an 08 engine.
Premium Member
If you were looking a the 3.6L
I know that the 2009 Jeep 3.6L will work in a 2003 Dodge Ram
You just have to switch over those 2008 things that screw into the engine block & change the intake manifold, some parts may be the same on both engines
Your trucks computer is looking for the things that came on the truck from the factory
The engine block itself does not care what type of fuel you use
It is the bolt on stuff that determines that
Discussion Starter · #5 ·
2009 Dodge Ram 4.7l Compatiability Chart
I received the following compatibility chart from someone on ebay.
Note that the ebay compatibility program at the bottom of the ads said something different but I was told not to rely on this.
Can anyone confirm the following will work as a replacement for a 2009 dodge ram 1500 4.7l
It is compatible with the following:
GRAND CHEROKEE 08 4.7L, VIN N (8th digit)
ASPEN 08 4.7L, VIN P (8th digit)
ASPEN 08 4.7L, VIN N (8th digit)
DURANGO 08 4.7L, VIN N (8th digit)
COMMANDER 08 4.7L, VIN N (8th digit)
GRAND CHEROKEE 09 4.7L (VIN P, 8th digit)
DAKOTA 09 4.7L (VIN P, 8th digit)
COMMANDER 09 4.7L (VIN P, 8th digit)
DAKOTA 08 4.7L (VIN N, 8th digit)
DODGE 1500 PICKUP 09-13 4.7L (VIN P, 8th digit)
GRAND CHEROKEE 08 4.7L, VIN P (8th digit)
COMMANDER 08 4.7L, VIN P (8th digit)
DURANGO 08 4.7L, VIN P (8th digit)
DURANGO 09 4.7L (VIN P, 8th digit)
DODGE 1500 PICKUP 08 4.7L (VIN N, 8th digit)
ASPEN 09 4.7L (VIN P, 8th digit)
that is the same list I have seen... take a look at the intake... the older ones that won't work are magnums... Im actually in the same boat... I have an 09 and putting in a jeep 08 4.7 motor... they are compatible
1 - 6 of 6 Posts
