1 - 3 of 3 Posts
Can I put a 2008 Ram 1500 4.7l engine in a 2009 Ram 1500 with a 4.7l engine. Blew my 09 and not sure if these are compatible. Will the 2009 flex fuel option be a problem.
I'd think you'd need the 2008 ECM/computer. I swapped a 2006 transmission into my 05 Magnum, once I swapped in the 2006 TCM, everything was fine. It's possible, your dealer could reflash yours to work, also.
1 - 3 of 3 Posts
