I wired in led light strips in the bed of my truck. I tapped into the wire for the cargo lights and ran it from inside the truck all the way back to the taillight. Once I got the ground correct all the lights came on with the key fob by unlocking the doors and also by pressing the cargo button on the dash. When I put the third brake light back in all that happens is one flash from the cargo light on the third brake light and the led strips I installed. When I push the cargo light button in the cab it flashes once but the lights will not stay on. I also can not find the fuse that goes with the lights, so I can check it. The third brake light cargo bulbs are the stock halogen don't know if changing these to le will fix that issue. Need help on where to look.
2018 ram 2500 HD
6.4l hemi
2018 ram 2500 HD
6.4l hemi
