Where are you guys mounting your cb radios in your 01 rams? thanks
There was a small switch panel there but it wasn't tall enough or wide enough for the scanner. I just measured for the opening, cut it out to about an 1/8" of the correct size with a Dremel, then S-L-O-W-L-Y hand filed the rest until the scanner fit nice & snug in the opening. I used the mounting bracket for the scanner and added a wooden block to it for height to mount it to the framework of the dash.Upstater has a nice-looking setup there. That looks like my instrument panel. I'd like to know how he fit that scanner in there so nice and neat. Does the panel have a removable cutout or something?
