1 - 5 of 5 Posts
Really want more sidewall on my 2012 Ram 1500 Crew 4x4. It has the oem 20" wheels now and they are peeling. So what better time than now to swap.
I am leaning towards the Rebel 2015-2018 17" wheels . AND keeping the same height tire I have now, which are duratracs. Wouldnt mind going a little wider though.
Anyone know if the 2015-18 Rebel wheels will fit a 2012 with no issues?
Detroit wheel and tires shows the rebel wheel as a 18.05 offset and the 2012 20" I have as a 19.05 offset.....what will be the result? Wheel sticks out a little more right?
Is it safe to assume this is a direct swap wheel wise with no issues?
Discussion Starter · #4 ·
I lucked out and found a real nice set of 2016 rebel wheels for $300!
So now I have to decide on the tires.......I have 275 70r 20s on it now.....I would liek to stay the same height or maybe justa little taller....and wider....I have flares I added and bilsteins up front that leveled up the truck.....
I think someone else here said 295 70 17s is as big as I can go with my bilsteins?
guys running 35s with the bilsteins. the 20s are 33 from the factory. 285/70r17 will fit on a stock truck no problem. im not aware of a 295/70r17 tire made but there are 315/70r17 out there.
1 - 5 of 5 Posts
