1 - 4 of 4 Posts
Discussion Starter #1
I need to find out if it is possible to reprogram the level for the tpms.... with the new wheels and tires I need to run different pressures.... anybody?
E
You need to run a higher pressure, right? Then you don't need to reprogram. If you had to run a lower pressure then yeah, you might need to.
To the best of my knowledge, this can only be done by the dealer. :4-dontknow:
Ya, can only be done through the dealer and if your air pressure is about 15-20 psi higher than the normal (35 psi) then I would take it in and ask them to update it, will save your tires if they do end up getting a nail in them.
1 - 4 of 4 Posts
