1 - 7 of 7 Posts
Has anyone verified the 7 prong trailer plug sends charge voltage to the batteries on a towed trailer that is properly equipped to accept a charge from the tow vehicle?
I have a 2015 Big Horn. Which pin in the plug carries the charge voltage so I can verify it's functioning properly?
Thanks in advance.
I was thinking the center, should be easy to verify by using a tester and see witch one has constant currant
Check the battery voltage on the trailer without it being hooked up. then hook it up and start the truck. You should see a change in the voltage. It should be what the truck is putting out to the truck battery. At least I think this would work to verify it. Could be wrong and I am sure someone will let me know if I am.
The center of a 7 pin trailer connector is for reverse lights. The + pin is #4 and ground is #1. I can't believe how many other variations are shown on the 'net though. As long as the trailer pigtail has the #1 pin wired it would provide voltage to the battery circuit.
Sometimes the center pin is called auxiliary but if you check it with a test light it will power with the reverse lights.
1 - 7 of 7 Posts
