It sounds like you might have a worn bushing or ball joint. Check the lug nuts to be sure they are tight.
There were some threads where guys had a clunk that no one could find. Turned out the factory hadn't torqued the cab boots down properly.They loosened cab bolts for a front end clunk?
Well, I'd be going to a new repair shop.
Load the front end and have it checked.
Better yet, ask for an alignment check...they should find it then...LOL.
This sounds like what I got! You wouldn't happen to have more information on that - bulletin number or location of support?The last couple of weeks I have heard my noise more in cooler temps. The other day, I got in the truck and as I positioned myself on the seat, I heard the clunk noise. I rocked myself side to side and heard the noise.
Went back to the dealer and had him listen. He said he had read a bulletin about loose center dash supports. Well, that's what it was. He told me the bolt was loose on the left side.
Just to let you guys know, you will hear this clunk noise and feel it in the steering wheel. Sounds and feels like something is loose in the front end.
Hey trucknutz - check this out, came across it when I was searching for my problem - https://www.youtube.com/watch?v=oyjWCAE_DnwMy 2012 1500 has some play in the steering, and kind of shakes and clunks when going slowly over bumps. (like slowly through a field, or slowly over washboard). Any idea what this is?
Found it - TSB 23-001-15 - this fixed my problem too. It really does sound/feel like something it popping or loose in the steering/front suspension! I've been trying to hunt this down for months - thanks for posting Mulveyman!The last couple of weeks I have heard my noise more in cooler temps. The other day, I got in the truck and as I positioned myself on the seat, I heard the clunk noise. I rocked myself side to side and heard the noise.
Glad I could help someone..:smiley_thumbs_up:Found it - TSB 23-001-15 - this fixed my problem too. It really does sound/feel like something it popping or loose in the steering/front suspension! I've been trying to hunt this down for months - thanks for posting Mulveyman!
So what did your buddy find? I having the same issues.I felt a light "popping noise" from front drivers side when turning my wheel 75-100 % rotation. I only experienced this after putting a levelling kit in. Dealer wasnt able to replicate the noise until the 3rd booking. He broke down my front end greased it. Rehung it. Said he then dropped it to the floor let is sit and then raised it and retprqued everything. For the most part the noise has gone. I thought i may have felt/heard it a few more times. They could not pin point the issue. They went so far as to replace a strut assembely. A buddy had a similar issue. Got fed up with the dealership snd bought a chassis ear and located it himself.
Do you happen to have the bulletin number? I’m having a similar noise.The last couple of weeks I have heard my noise more in cooler temps. The other day, I got in the truck and as I positioned myself on the seat, I heard the clunk noise. I rocked myself side to side and heard the noise.
