Hello,
I recently had the cluster go out on my 2002 Dodge Ram 1500 SLT (4.7 V8)
I purchased the truck used with only one key (black factory key, no chip)
I ordered a cluster from ebay, which appeared to be an exact match but had a RKE receiver on the back. I installed it and everything seemed to work until I started the truck and the alarm started going off.
I have taken it to the dealership, who was happy to charge me for an hour of labor but would not disable the alarm and could not program a fob, as well as an independent shop who attempted to disable the alarm but were also unable to do so.
I looked around the net for a pinout diagram but did not see anything that would help. Seeing as the truck starts and drives I'm assuming its just a matter of disconnecting a wire somewhere, but I'm stumped.
...and apparently I'm incapable of starting a sentence without "I."
EDIT:
During a self diagnostic I found the following C- Codes:
64 10 - Driver door Lock Open Circuit
6E 10 - Driver Lock Switch Circuit Stuck
81 00 - Remote Radio Switch Input Circuit High
A3 68- Battery Voltage Open
A8 20 - Vin Previously Stored
AA 08 - PCM Messages Not Received
AE 68 - ACM Messages Not Received
AF 00 - Skim Messages Not Received
EDIT:
