1 - 13 of 13 Posts
How can this be tested? My Ram has 86,000+ now, and seems to be running a bit hotter than usual. It's been a hot summer, so I am sure that adds to the problem.
Thanks
Super Moderator
How hot is hotter than usual?
Super Moderator
Yes but you said the truck is running hotter than usual. How hot does it usually run and how hot has it been running?
Super Moderator
That seems normal. My coolant will get to 221 unloaded before the shutters and thermostat open and bring it down
Super Moderator
Oh whoops, no the shutters are 2013+ only.
I wouldn't really be worried either way
Discussion Starter · #10 ·
What are the shutters for, anyway? I had a 2016 Ford F150 as a work vehicle, and it had the shutters. One day I observed that the outside temperature was not changing. Found out that the shutters had malfunctioned, and was causing the engine to overheat and the AC to shut down. Got it working again on my own, but wasn't impressed by the technology.
Super Moderator
They help get fluids up to temp quicker, which increases the service life of pumps and other components, and improve aerodynamics
Super Moderator
1 - 13 of 13 Posts
