hydrex, it is number 2 coil.
thunderhawk, yeah I thought it might be able to be tested. Probably could compare it to a good one.
Well as it turned out , the coil was heat damaged near the bottom rubber and the glue was melted and gone. It was obvious compared to the others, so I put a new coil pack on cylinder 2 and it runs fine. Glad it wasn't an injector. New NGK plugs as well.
As I was putting new plugs and coils back on I noticed #1 and #3 coils had two faint splits in the plastic that I can only attribute to heat as well. Have to replace those in the near future.
Thanks for the replies and thunderhawk, good luck on your diagnosis.
Chris
