1 - 12 of 12 Posts
Hi Benny,
Tried to PM you, but I guess I need 50 posts...:shakehead:
I had an idea about making a custom column "electric" shifter. I know there is some heavy customization needed. I wanted to double check the column parts I would need for this project. Here is what I found:
Column Cover - (1GD32DX9AC)
Shift Lever - (1TM081X9AA)
Bracket-Gearshift - (5057506AF)
Would I need any other pieces?
Thanks, Alan
Mopar Online Parts
Hi Alan,
You should be able to PM soon unless there was a change, I thought it was 20 but it may be 30 posts.
In any case I am not sure what you need as you are developing this modification so I am not sure what your working with. Is there a specific year and transmission that your looking to obtain the column shift parts from?
-Benny
Discussion Starter · #3 ·
I wasn't sure if I should look at the 2017 2500 parts or go to the 09-12 1500. The parts I referenced above are from the 2500. Still working on some kind of linkage from the column to the dial. (I have a 2017 1500)
Discussion Starter · #5 ·
Lets go with referencing the 66RFE that comes with the 5.7 or 6.4 on a 2017 2500. I have the 8HP70. I realize I do not have the correct internal column, but I have read threads where folks swapping from console shifters to column have been able to.
Mopar Online Parts
Here is a list of parts you would typically need for adding a column shifter
68263752AA
68263753AA
6511860AA
6511861AA
68261256AC
As for the column covers I need to know what color you currently have and for the knob/lever what color and finish knob. Example black urethane, black leather , brown etc...
Thanks,
Benny
Discussion Starter · #7 ·
Thanks Benny!
Black for the column covers, and black lever with either plain 'ol black plastic handle (if that's an option) or black leather handle.
1 - 12 of 12 Posts
